Got the ceiling transition from double wall in-has a male crimp end, stove receives male , how with no clearance does one slip this in? A slip/adjustable will not make the connection! Whats the trick! Method? Thanks Keith n Kansas
Just what I did! But took a floor/car jack lifted the back up, took the rear legs off, dropped it down till I could slip the pipe in & with two people one jacking & one working the top in then slow lifting with the jack working the bottom in, worked super! Just make sure your stove is well centered (PIPE) & is very close to the length you need! THANKS FOR THE INPUT! Got a nice tight fit with less money for fittings & also a better look! Thanks again! Keith n Kansas
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
