need help identifying a stove
drtnshtr
204
Ohio
any help?
If there wasn't what looks like a typical spring type handle there, I wouldn't have thought that there's a stove in that pic...
Got one with a little more lighting?
wow the pic looks much clearer than that to me....anyone else?
Pitch black with a few goldish spots to me.
Those that cannot see the stove are running their computer display properties at less than 1280 x 800 pixels.
Go to control panel then click on display then click settings to change display. ;-)
For stove identity Go to this link
https://www.hearth.com/econtent/index.php/forums/viewthread/3359/
scroll down to member Jabush
Look like your stove?
Looks good to me, but excellent id and tip Dave_1. So this would be an Atlanta Stove Works - Huntsman Model 241?
thanks for the help guys..this stove is on craigslist right now for $250 ...is this a good deal???
I don't know what make that stove is, but it is not a Huntsman. It doesn't look like anything ASW made AFAIK.
What does the inside look like? Is there a baffle?
drtnshtr said:
any help?
I do not own the stove but there is one on craigslist for sale in my area...
Oops...sorry, had a few drinks last night.
The stove looks like a typical "classic" from the late 70's early 80's. Most likely thick plate steel with a cast iron door. Hard to tell how it might burn without seeing the inside. As you probably gathered from reading this board, firebox design varied greatly back then. If you can get a closer look and verify that there is some sort of baffle in the firebox, then the stove has the potential to run fairly clean with decent burn times.
As far as the price...that thing probably cost $250.00 brand new.
