need help please
welcome to the forum!
I found the p61 manual online:
http://www.harmanstoves.com/doc/P61-2_r5.pdf
You should download a copy for your reference. Page 14 indicates the following:
3 Blinks: Indicates ESP (Exhaust Sensing Probe)
failure. This requires a manual reset*.
* Manual reset, disconnect power cord for a few
seconds and reconnect. If error still occurs call your
Dealer.
this stove isnt feeding enough to burn
we have fire but the fire is only in the back of the pot
and there is no heat
i did just unplug but it still the same ughhhhhh
denandpaula,
I suggest you download the manual and read it. As abrucerd stated. You will learn alot from the manual.
On Page 18 it states that feed motor will not run until the ESP reaches 165 degrees. So if the ESP has issues it won't run!
How long have you run thus stove and how much pellets have you ran thru the stove? You might need to do the seasonal cleaning.
Your exhaust maybe dirty or plugged??? or the ESP maybe bad. Try the major cleaning and run it again. Then call someone for service if it still doesn't run.
Good luck.
Jay
