need help with E code
the code is for vacuum loss, check the silicone hose from the vacuum switch to the exhaust chamber for a crack or leak in the hose. if this switch opens the stove thinks your flue is plugged up and will shut you straight off with an E.
the E is the same as an E-1 with the current models.
