Need Help with My Chainsaw
Mass. Wine Guy Posted By Mass. Wine Guy, Mar 13, 2013 at 3:33 PM
  1. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    Northeastern Massachusetts
    I was sawing today with my Jonsered 535 and he saw got pinched in the limb I was trying to cut. After a while I got it free. But now the chain won't move at all. It feels like the chain brake is on and the plastic piece in front that activates the brake goes back a lot further than it normally does. I haven't yet taken things apart to see what I can do. Any ideas? Did the bar get bent?
    I'd be very grateful for your help and suggestions.
  2. BobUrban
    BobUrban
    Minister of Fire 2.
    NULL
    Jul 24, 2010
    1,922
    1,136
    Loc:
    Central Michigan
    Pics??
    Pull the clutch cover off and remove the bar and chain - clean it all up and replace it. test for mobility. Likely it is just jammed up with chips and dust either in the tip or gear but tough to know without more details and pics.
    Start simple and work your way out.
  3. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    Thanks, Bob. I'll disassemble and clean the saw and see what's what from there.
  4. thewoodlands
    thewoodlands
    Minister of Fire 2.
    NULL
    Aug 25, 2009
    10,825
    2,930
    Did you pinch the bar so bad that it pushed the groove in the bar closer together, that would cause the chain to be stuck in that area or stop it from rotating.
    Thistle, ScotO, BobUrban and 2 others like this.
  5. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    I wish I could answer that. It was really tight and I did twist the bar trying to free it, so who knows? Can these things be repaired? Probably not worth the cost.
    Can anyone recommend a good narrow kerf bar (.50 gauge, .325 pitch), preferably machined, not laminated?
  6. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    zap likes this.
  7. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
  8. thewoodlands
    thewoodlands
    Minister of Fire 2.
    NULL
    Aug 25, 2009
    10,825
    2,930
    When I did it I just took a screwdriver to open up the groove to the original size.
    ScotO, Fifelaker and BobUrban like this.
  9. BobUrban
    BobUrban
    Minister of Fire 2.
    NULL
    Jul 24, 2010
    1,922
    1,136
    Loc:
    Central Michigan
    A new bar will run somewhere in the 35-50$ range so, although not a bank account breaker, more than just chump change for me. Like I mentioned, start with cleaning it up and if the bar groove is pinching the chain it will be rather obvious right away. If so, follow Zaps suggestion and ease it back open with a screw driver or your squench. May as well get it working if at all possible even if it just becomes a back-up bar. Having a second bar can be priceless when you get the new one stuck. Pull the head off and add the second bar and chain to cut the pinched bar out. Not as convenient as a two saw plan but a whole lot cheaper.
  10. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    I took my saw apart. The bar looks fine as far as I can tell (which may not be too far). The chain brake appears to be broken, as in when I put it together the brake handle doesn't move back and forth. Since my chain didn't move at all the other day, I'm thinking this is the issue.
    Does anyone know a source that sells replacement brake assemblies for my 535?
  11. ScotO
    ScotO
    Guest 2.
    NULL
    Here's one on ebay that should work on your saw....
    http://www.ebay.com/itm/jonsered-455-chain-clutch-brake-handle-NICE-OEM-/261144958476?pt=US_Chainsaws&hash=item3ccd73d60c
  12. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    Scotty, I can't thank you enough! That looks perfect.
  13. ScotO
    ScotO
    Guest 2.
    NULL
    No sweat! Glad I could help. Keep us posted on the repairs....
  14. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    I don't know how, but the brake mechanism must have become stuck when I pinched the saw. I took the saw apart, cleaned it and reassembled it. The chain went smoothly around the bar until I screwed the clutch cover/clutch brake on. Then it wouldn't budge. I am totally unskilled in mechanical things, so I could be missing a lot.
    I sure wish I could afford a new saw and keep this as a backup. But I can't.
  15. BobUrban
    BobUrban
    Minister of Fire 2.
    NULL
    Jul 24, 2010
    1,922
    1,136
    Loc:
    Central Michigan
    Another great, great place to get saw help is Arborist.com I can all but guarantee someone there in the chainsaw forum will know exactly what happened, how it happened, how to fix it correctly and have two or three McGyver tricks to get it through a day of cutting if necessary.
    That place is to chainsaws what Hearth is to burning wood for heat.
    IMO - if you are going to play here and more importantly play with the tools necessary to gathering the raw materials to play here - sign onto Arborist and get to know those guys too. It will save some headache from time to time.
  16. Mass. Wine Guy
    Mass. Wine Guy
    Feeling the Heat 2.
    NULL
    Nov 23, 2007
    311
    11
    Loc:
    You must mean arboristsite.com. The one with all the forums. Good idea. Thanks.
  17. MasterMech
    MasterMech
    Guest 2.
    NULL
    Not that we don't have a couple mechanical type individuals here on Hearth. :mad: ;)
    Any chance the brake is set and you just need to release it? I'm guessing the cover didn't come off/on easily? I would try to work the brake handle with the cover off first and make sure the band contracts/expands as it should.
    Wildo likes this.
  18. BobUrban
    BobUrban
    Minister of Fire 2.
    NULL
    Jul 24, 2010
    1,922
    1,136
    Loc:
    Central Michigan
    I apologize MM - I am thinking I should have said, "there is a whole site full of MasterMechs" over there. And yes - that is the site.
  19. MasterMech
    MasterMech
    Guest 2.
    NULL
    It's all good. Just bustin' some chops is all. :p
    Truth is, the AS crowd are true enthusiasts when it comes to chainsaws and many of them dig in deeper than even I go. My game is with stock equipment for the most part and I'm still a rookie when it comes to changing the internals for mo' power. ;lol
