Ok, this is for a customer, just looking for ideas and thoughts.
Ranch house. Two masonry fireplaces stacked. He wants a wood insert in the basement. By inspecting the flue from both ends I determined it offsets around the main floor firebox and then back to center again. The main floor one offsets as well (for no apparent reason). Why masons why... why do you do such horrible things to us. Anyway... ID of the clay tiles is 7" x 11.5". A insulation wrapped 6" liner would never get down there. The tiles luckily seem to have been installed very well. They line up nice and there is not giant mortar blobs coming out of the joints. The oval rigid pipe I am always touting is out, due to the double offset. The offsets appear to be about 30 degrees.
Here are some of my ideas.
5.5" flex with insulation, should be just under 7" with the insulation wrap. Might be a tight squeeze still. Also Quad has not tested for this size liner, so they basically have no comment on the subject.
6" flex ovalized to 5" x whatever (approx 7.8" by my calculations)(or smaller if needed?). - The offset are lengthwise, would this flex well that way? Previous expiriance tells me it would not, but thats with simpson's oval to oval duraliner. This would be either duraflex ovalized, or something special order from another vendor.
6" flex liner with poured insulation. Would need spacers to keep 1" from tiles. Would this be any better than the insulation wrap? Doesn't seem like it would.
