Need info on Sears wood heater
Stefan200
5
north Georgia
I recently acquired a "Sears Air-Tight Wood Heater", model no. 143.841540 (per label on back). It's heavy (300+ lbs). It has not been used much. I got it out of house built in the mid-1980s.
I've searched for info about it, but only found a diagram and parts list on the SearsPartsDirect.com web site. I discovered there is also a blower assembly for it (which I don't have). The blower body and motor are no longer available (bummer).
The owners manual is no longer available. Does anyone know where I could get a pdf file of it?
Part of the label has been ripped away. There is a nearly-unreadable seal on the label with the year 1940 on it, but this stove does not look that old.
Can anyone tell me a bit about this stove? Years built? Max btu? Wood size? Anything interesting? Warnings? Advice?
Thanks in advance,
Stefan
As a Fischer stove knock-off most of what you find in our Fischer stove forum will apply.
https://www.hearth.com/talk/forums/fisher-stove-information-parts-history-and-more.28/
Thank you. It looks like I may have the Mama Bear knock-off, though I can't seem to download the manual for the "Bear Series VI ; UL listed single door stoves ( copyright 1980 ) later cathedral door".
I am very new to all this. Trying to learn. Did Fisher make this Sears-branded stove or did Sears make a copy or just contract someone else to make a copy?
Lots of people copied the Fisher stoves.
