HI All!
Got our Vermont Castings Intrepid II hooked up today with the chimney liner. Seems to be working well. Ran up the hardware store to get a magnetic thermometer so we don't have learning curve issues.
So according to the directions, when the stove gets to 450 degrees you flip the damper to use the cat. If I get the stove too hot, I know the close up the other damper on the stove. So would it burn cooler or hotter with the CAT flipped on or off? Trying to figure this out since I know sooner or later I will need to know!
Also, what do I do at night time? I think I would load the stove for the night and cut the damper back to burn slow. But what about the CAT? do I burn it with the cat or burn it without? As the stove cools overnight, it will be too cool for the CAT so wouldn't that damage it? I don't know if everyone is familar with the stove, but you burn it with the damper CAT bypass open when you start it, then bring it up to 450 degrees, then flip the damper so the smoke runs through the CAT.
Thanks for any advice! Hubby seems to like it and everyone is happy to not have to run downstairs to feed the big old wood eater in the basement that makes the house either way too hot or way too cold!
