Needed a new stove
Jdog Posted By Jdog, Nov 12, 2013 at 1:45 PM
Thread Status:
  1. Jdog
    Jdog
    Member 2.
    NULL
    Oct 15, 2013
    129
    11
    Loc:
    Mineral wells wv
    Ok guys if you remimber i had the 13-nc golden eagle and was having all sorts problems as i tried to burn the first few fires were ok then went down hill badly ended up the inside of the fire box had 5 cracks inside from inch to 13/4 long and big enough to put a butter knife in. Some where in the square tube where the air comes to the secondary tubes and what not big mess. SOO i went out and bought me a brand new 13-nc and am hooking it up tonight hope this one is easy to use i was pulling my hair out what i got left bc i kept reading on here people raveing over them and i couldnt get 20-30 min burn time and it wouldnt stay at temp for more than 3-4 min then start dropping off no matter how how i got it or where i ajusted the air and reloads one after another with all the hot coals in there from a burn 5 min ago still had to use kidling to get it back up burning. Lets hope this time with a new stove it will run like it should. Should i burn it out side first? Small fires or straight to big fires heating my house?
  2. lopiliberty
    lopiliberty
    Minister of Fire 2.
    NULL
    Oct 7, 2011
    912
    288
    Loc:
    Mineral County, WV
    If its possible I would burn it off outside if you can. Start out with small fires and increase the temperature each time. Even though you burn it off outside, every time you reach a new high temperature inside your going to get that pain smell but it shouldn't be as bad the first couple of fires outside
  3. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    Sounds about right...
    The smell is manageable (depending on how sensitive you are to such stuff) but as long as you haven't hooked it up yet, I'd sure do it outside.
  4. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    remember to add some pipe to the top of the stove to pull it when you do your preburns outside. basically a kindling fire just keep adding kindling as it burns it up, after a couple hours of good burning should get rid of the oils in the steel and paint curing.
  5. Jdog
    Jdog
    Member 2.
    NULL
    Oct 15, 2013
    129
    11
    Loc:
    Mineral wells wv
    What about all the little like beads that were in the round intake hole in the back? do they serve a purpose or what? Do you guys recommend putting stove cement in the flue when i put the pipe in to seal it up
  6. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    That is "shot" from the shot peening booth at the factory. The stove is blasted with those things to condition the steel. Nothing but trash now.
  7. BCC_Burner
    BCC_Burner
    Feeling the Heat 2.
    NULL
    Sep 10, 2013
    339
    117
    Loc:
    Wasatch Front: 7800'
    Those are left over from machining the stove as far as I can tell. I vacuumed my stove out completely before installing the fire brick. Even with a couple break in fires outside, you are still going to get paint smell. I have been burning daily in my 30-NC for about 5 weeks now, and I am still faintly smelling paint when the stove gets hot. It doesn't smoke any more, but man, they emit some chemical-y funk for a long time.
  8. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    I did too for quite a while.
  9. Jdog
    Jdog
    Member 2.
    NULL
    Oct 15, 2013
    129
    11
    Loc:
    Mineral wells wv
    BB i was hopeing you would chime in on anyone eles new 13 or 30 i supoese if you look thru the 3 inch hole in the back and see where the rod in the front slides that peice in there back and fourth when its pushed all the way in it doesnt close all the way is this normal? And i was thinking of installing an oak any likes dislikes on the oak?
  10. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    the little beads are from the shot blasting process, they arent part of the stove , if ya want just vac em out, wont hurt anything. as for sealing the pipe s its beneficial to do so, but dont do it for the outdoor preburn would just make a mess breaking it right back loose to reinstall
Thread Status:
