    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Curly New Member
    Wilmington, DE
    I've been using pieces of duraflame log to start these fires too. I cut them off the log and form them into the size of a golf ball. Works well unless you advise it's not a good idea. Thoughts?
    #26
    Helpful Sponsor Ads!
  2. etiger2007 Minister of Fire
    Clio Michigan
    Read the do's and dont's on the package, seems like I bought some of those before and it said not to use in a wood stove, I could be wrong. I ended up getting rid of the ones I had bought.
  3. Curly New Member
    Wilmington, DE
    It says don't burn the log in the insert because of higher burn temperature and wax in the logs but I figured a small piece just to start the fire couldn't hurt. It only burns for about 15 minutes then the wood takes over.
  4. raybonz Minister of Fire
    Carver, MA.
    I doubt that little bit would hurt anything especially if you have a secondary burn stove..
    Ray
  5. jwoair23 Member
    Pittsburgh, PA
    Curly,
    Just another option to consider, I use fatwood to start my fires, which works just as well (better?) than the duraflame. The only reason I bring it up is its a lot cheaper, especially if you buy it from here:
    http://www.llbean.com/llb/shop/38687?productId=591297&subrnd=0&qs=3016887_pmd_google_pla
    They also sell it in walmart, but thats $10 for a 5lb box. If you buy either the 25-35 lb box, you should be set for 1-2 years with fire starters. It takes about 2-3 for me to get it going.
    Happy burning!
    Curly likes this.
  6. etiger2007 Minister of Fire
    Clio Michigan
    You should be fine Curly. Hows the insert treating you? Getting good burns?
  7. Curly New Member
    Wilmington, DE
    So far pretty good. I'm getting used to what this thing can do and how the moisture in wood can be a pain in the @ss. I had some problems with the wood I got but was able to find a guy close to me who has some truly seasoned wood on a 15 foot pile. Nice and grey from the sun and I was getting 8 to 12% readings on the moisture meter. I had some decent wood last week but needed more so I called the guy who cut my tree down and he said he had some "seasoned" wood. He dropped it off this past Saturday while I was at work. I came home and when I saw the pile, I thought there is no way that wood is ready by the color. I was right, I took some readings and it was hovering around 23 to 25%. No big deal again, I'll use it next year. In other words, I have about 2 cords of wet wood stored. For comparison, I checked the moisture on the Oak I had taken down a few weeks ago and it was reading 40 to 45%. Man, I never realized there's a science to burning wood. Before the insert I was a campfire guy and all I needed was a full wax log, about ten pieces of any kind of wood and a beer.....whoosh!.....heat......lol. That in no way applies here.
    chazcarr and raybonz like this.
  8. etiger2007 Minister of Fire
    Clio Michigan
    Your right and its a science for sure. This is the first year I have burned this insert and I think last night I found its sweet spot. I loaded the stove as I always do, what I did different was I cut the air down to 3/4 open at a stove top temp of 300 or 325 (before I would wait until after the stove top would hit 400 to start dampering down) basically the first sign of secondary combustion then I cut it back when the stove hit 425 or so ( now Im half way closed) Then When the stove hit about 475 i went to a 1/4 open and I left it there. I had great a great secondary burn and the tubes never got red hot while burning the gases. This tells me that the wood was not off gassing too fast and wasting wood. The stove hovered around 550 for the first couple hrs then down to 450 for awhile. I loaded up at 9pm and reloaded at 4am, followed the same routine and had the same results in the morning. No glowing secondary tubes and awsome secondaries. Just had to share.
    raybonz and Curly like this.
  9. Curly New Member
    Wilmington, DE
    One more thing and let me know if this happened to anyone else as a new burner. My right arm, between the elbow and the bend in my arm, now has a few "tattoos" from the insert door. Yup, I made a mental note to always open the door all the way but forgot a few times while loading wood. By the time I hear the sizzle, it's to late, !!! lol
  10. etiger2007 Minister of Fire
    Clio Michigan
    Like these? I have made up a sleeve since my burns. I look like I have behavior problems LOL
      File size:
      35.8 KB
      29
    chazcarr, BrowningBAR and Curly like this.
  11. raybonz Minister of Fire
    Carver, MA.
    Curly likes this.
  12. David Tackett Member
    Waynesburg, Kentucky
    A lot of these guys say 2-3 years on oak, but I use oak that is 12-18 months old. It was 111 degrees here this summer and it was over 100 most of July. My oak is perfectly dry. There are a lot of factors on how dry your wood is, air flow around it, dryness around it, etc... The 2-3 years is a guestimate. YMMV.
    Curly and raybonz like this.
  13. raybonz Minister of Fire
    Carver, MA.
    Sounds like you could create a solar wood drying kiln there Dave... How is the humidity at your location?
    Ray
  14. Curly New Member
    Wilmington, DE
    Ed, I had to laugh when I saw the pic..... I feel better now, I'm not the only one. You have the nice long burns and mine look like a connect the dots puzzle. Now if I can only stop scratching them. You look like you have behavior problems and I look like a junkie that needs a fix. ;lol
  15. etiger2007 Minister of Fire
    Clio Michigan
    LOL for sure, I got myself a welders sleeve, I cant be walking around like that.
    Curly likes this.
  16. Curly New Member
    Wilmington, DE
    Damn. Cleaned out the ashes today and noticed the two bottom fire bricks where they meet dead center are crumbling. I thought they lasted longer than that. For now until I hear from the dealer, I just flipped them over. Thoughts?
  17. corey21 Minister of Fire
    Soutwest VA
    Welcome nice stove wood and chimney.
    Curly likes this.
  18. dafattkidd Minister of Fire
    Long Island, NY
    Hey Curly, hope you're enjoying your first season with the new insert. Can you post a pick of the crumbling you are seeing? That sounds like the dealer needs to replace those damaged firebricks for you.
    Also I used to have an insert with a 1.7 cf firebox. This thread was very helpful to me http://www.hearth.com/talk/threads/tips-for-small-fire-boxes.57987/
    Hope that helps.
    Curly likes this.
  19. weatherguy Minister of Fire
    Central Mass
    How long are your burns now Curly, also I wanted to mention when you check your wood for moisture are you taking a split and splitting it again and taking the reading in the middle with the pins going north south with the grain?
    Curly likes this.
  20. etiger2007 Minister of Fire
    Clio Michigan
    Curly how have you been doing? Hows that insert treating you?
  21. Hogwildz Minister of Fire
    welding gloves work well.
  22. Curly New Member
    Wilmington, DE
    Still waiting to hear from the dealer. I've been burning about 5 nights/days a week since around the middle of November. I have wood that is dry (8 to 12%) and I usually split it once more and use it to start and get the fire going. I have wood that is around 20% or less moisture that I split and throw on the fire when I have a nice hot bed of coals. I usually run it with the draft about 50% closed. If the wood doesn't burn as well as I thought it would, I'll open the draft all the way. I can't get an all night burn without getting up to load more. The box is small, 1.4 cubic ft. The crumbling I'm talking about is dead center right in front of the draft port. I figure that area gets the hottest with the air coming in. The area is about the size of a silver dollar and about 1/8 of an inch deep. If I don't hear from the dealer, I'll just have to go to him and try to get a satisfactory result. They treated me very good and I don't expect there will be any problems. In the mean time if necessary I'll buy my own bricks and cut them myself. I already looked online and a replacement set for my insert is close to $70. They can shove that price especially since I didn't get 3 months out of the first set. Well, not the whole set but the two bottom bricks. Thanks all.
  23. HomeBruin New Member
    Califon, NJ
    Welcome to the forum! Wow, can't believe firebricks are crumbling already. I just bought a Regency insert too, the HI300 Hampton. My tubes glow a little bit now and then when I'm trying to get 'er going good too, but no other stove parts ever glow, so I think we're OK. Those tubes are designed to take a lot of heat. I was lucky enough to have a cord of wood left over from last season, which burned great. Now burning wood I procrastinated and didn't get until just before Sandy. That wood is a PITA to get going, have to keep cracking the door open a few times until it finally goes secondary. Got a moisture meter from Lowes and figured out why: The older wood was 17.5%, burned great the new wood is only down to 23%. Make sure you split a log and measure from the freshly exposed inside surface or you won't get a true reading. At 23%, the wood isn't so wet as to hiss or spit moisture, but it sure is a pain to get going in the morning.
    Curly likes this.
  24. Jjm457 New Member
    SW Virginia
    Curly, I have the same insert and the same exact issue with firebrick (about 3 months usage or so). I haven't contacted anyone regarding this, but maybe I should. I also saw these at Northern Tool, and I believe they are the same size and can be cut to fit.
    http://www.northerntool.com/shop/tools/product_200325974_200325974
    Curly likes this.
  25. Curly New Member
    Wilmington, DE
    I talked to the dealer and he said it's not unusual for the brick to become brittle in front of the draft port and to make sure I have an inch of ash on the bottom. I've been cleaning most of it out everyday. Me? I think it's BS but not enough of a big deal to make a major fuss. I just kept the same side up and turned them so the brittle part is against the far right and left of the stove. Other than that, the only other minor issue is that circular cataract I get right in the middle of the glass after about 5 to 6 hours of burning. It wipes off in the morning and I'm sure some of the wood is a little damp causing the fog. Other than that, it's been working fine especially during the cold spell last week.
    raybonz likes this.
