Newbie looking for install picture forums...diy pellet floor protector
  • Install
    Votes: 1 33.3%
  • Floor protector
    Votes: 2 66.7%
  • Total voters
    3
zrtmatos
352
Connecticut
I am new to this forum but have looked before to find how to's and diy on building floor protection for a pellet stove, in my case a Lopi Leyden (2008 model). ;? I am unable to find a good forum with pics on making up a hearth floor protector and the install through a wall. o_O
Can someone steer me to it? ;?
By the way, I love this forum!!! :)
SCAS, do you have any build pics of how you put that together?
Smoke Show , any particular forum you know of or any search criteria to use?
Thanks TheMightyMoe. Nice install and pics. :cool:
Exactly what I was looking for. So no plywood base needed? ;? Just 1/2 inch ( I assume) backerboard/durock with tile affixed with adhesive? No problem with it cracking when you moved it into place? ;?
How did you attach the wood trim? I missed that part in your install.
Just finished our hearth pad last night. Didn't take any build pics, but attached a photo if it helps you get a general idea. Basically a 40"x40" square with corners cut off. Used 2"x2" 's for main outline and internal bracing; half-inch OSB screwed to top of that, and finally half-inch cement board on top of the OSB. All the 2"x2", and OSB was glued and screwed; used layer of thin set between OSB and cement board; then tiled away. Border is cedar with a natural stain, and top coated with 3 coats water base satin. You will want to use special coated screws on the cement board so they don't corrode. Rented a tile saw from local hardware store. I'm a total amateur...just comfortable with hand and power tools...if I can do it, anyone can do it. Post pics when you get yours done.
That came out great, hard to believe it is not a commercial piece in a store! Thanks for the input, yes, I will post pics later on.
Somewhere I had seen someone tale outdoor patio pavers, and backed them with rubber as to not scratch the floor, and made an interesting hearth.
