My brand new stove is working though am not getting enough heat out of the front unless I'm running the heat range setting at 8 - 9 and the blower at 1 -2 above those settings. House is getting to 70 degrees in the main room where the unit sits. The air coming out is warm but not hot. I'm using Greenway pellets which seems to burn OK with little ash or clinkers. The unit came set at 4-4-1.
Also, there is a panel with a latch inside above the burn pot that I'm unsure what that is?
Many thanks!
Many thanks!
