    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Don2222 Minister of Fire
    Salem NH
    From your article
    That statement in bold from the article is not true!! My test show that the Branched Carbon Conductive Grease is Much More highly Conductive than NoAlOx !!!!
    So maybe I will prefer the MG Carbon Conductive grease!!
    #26
    Helpful Sponsor Ads!
  2. kettensäge Feeling the Heat
    N.E. PA.
    Probably why Neverseize works also, metal particles suspended in grease until mechanical action forces them together.
    Guess it comes down to run out and buy something or use what you got.
    Don2222- Super High conductivity may not be needed on a circuit connection capable of passing hundreds of amps. The circuitry inside an electronic device is a different story.
  3. oldspark Minister of Fire
    North West Iowa
    They mean in use under pressure, the Noalox is non conductive when its NOT under pressure, a electrical connection or in our case a battery terminal gives it its conductivity.
  4. oldspark Minister of Fire
    North West Iowa
  5. Don2222 Minister of Fire
    Salem NH
    Yes, that is true. Low or Non conductive grease is used on High Voltage or High Current connections. That is why non conductive grease like the electricians NoOx is used on 100 and 200 amp main circuit breaker wires in home circuit panels. Also why the automotive permatex non conductive di-electric grease is used on spark plug wires.
    However in low voltage and low current devices the higher conducting carbon conductive grease is recommended. So I would say the application should dictate what to use.
    My original problem that started this whole issue was with the safety switches in the wood pellet stove. They are low current at 110 volts. On my 3rd season with a new stove the spade lug connection failed and the auger was dead as a door nail. So to prevent this in the future I went with the carbon conductive grease.
    See all the troubleshooting pics and detail here. I also though it would be good on the battery terminals. Since battery terminals can also be high currect when starting the car, then either should work. I just like the high conductivity factor for the low current draws you get while driving in the daytime.
    See pellet stove issue here with pics and detail of troubleshooting
    http://www.hearth.com/econtent/index.php/forums/viewthread/80407/
  6. kettensäge Feeling the Heat
    N.E. PA.
    I wasn't criticizing, glad you went through the trouble to suggest it in the first place, reading this thread will give people several choices when they have battery cable issues to deal with.
    Thanks.
  7. Don2222 Minister of Fire
    Salem NH
    Hi OldSpark
    Interesting article. I like how he said dielectric grease was no good and praised the anti corrosive zinc paste until 07 when he put the meter on it!!! LOL
    I guess that is in the low conductive catagory!
    So it seems we all lerned something here. Thanks everyone
    There are 3 catagories of electric grease.
    1. Non conductive
    Example: Automotive Permatex Di-Electric grease and Electricians NoOx
    2. Low Conductive
    Example: NoAlOx and anti corrosive zinc paste. Probably many more
    3. Highly Conductive
    Example: Branched Carbon Conductive Grease such as MG Carbon Conductive Grease
    So maybe the Carbon Conductive Grease can be used in all but High Current and High Voltage connections, but the non conductive grease is not good Between contacts!
    Also Hig Conductive Grease is not good where it can bridge power to ground and cause a short. Like in mutiple pin connectors.
    Thanks again everyone for your comments!!
  8. Highbeam Minister of Fire
    Here's the problem, grease gets old and when hot especially can drool away from the connection. What happens when you have a slug trail looking slime of this grease between the connection and a ground source? Wouldn't that provide a path for current flow? A short?
    Especially in a plug type connection where multiple wires are being connected in one plug I would be very light on the amount of this conductive grease beign applied. Only the lightest film and even then, it's pretty risky that you'll cause more harm then good. There's a reason dielectic grease is used in this application, you don't want the grease to conduct power away from the connection. The metal tabs inside the connector will touch each other and provide that connection, the grease's job is to prevent oxidation from getting into the metal connection.
  9. Don2222 Minister of Fire
    Salem NH
    Very Good point, I have only been using the conductive grease in single pin connectors so far.
  10. oldspark Minister of Fire
    North West Iowa
    That one of the reasons they gave for useing the Noalox in some cases, I believe it was in the first link I posted.
  11. Don2222 Minister of Fire
    Salem NH
    One more point I want to make after using Ideal NoAlOx and MG Carbon Conductive grease is that the MG Carbon Conductive grease is thicker and not as drippy as the NoAlOx.
    Whatever that point is worth! LOL
  12. oldspark Minister of Fire
    North West Iowa
    Yea the Noalox can seperate also and you have to mix it when you use it.
  13. begreen Super Moderator
    South Puget Sound, WA
    In the past I have used a red spray coating that has been pretty effective. This was on boat battery banks which are in a saltwater environment. I checked on them around the 3 year mark and the terminals were still looking like new. Not sure the brand, this was a couple decades ago. But I see Oregon and others selling the stuff.
    http://www.amazon.com/CRC-Battery-Terminal-Protector-Sealer/dp/B004R9KJK6
  14. zap Minister of Fire
  15. semipro Minister of Fire
    SW Virginia
    Don, I suggest a better way to do this is to look at voltage drop across the battery connection under starter load. We did this at a repair shop that I worked at back in the 80s. You simply monitor the voltage between the battery post and the installed battery terminal while someone cranks the car. This measures the resistance of the connection under actual operating conditions.
    If I recall correctly, the type of grease made little difference. We tried wheel bearing and dielectric grease and vaseline petroleum jelly. All gave similar results.
  16. Don2222 Minister of Fire
    Salem NH
    There is alot of current with a car battery so the type of grease does not matter as much. However when you get down to the application of the grease, the non conductive grease should only be put on top of the connection to keep out the moisture. The Carbon Conductive Grease can actually be put between the connectors. Therefore I like the conductive grease better. :)
  17. woodgeek Minister of Fire
    SE PA
    Personally, I've had good luck with simple vaseline, in the contact space, not around it. The contact is designed to have one surface scrape the oxide off the other side, so a small cold weld forms between the two pieces of metal. This happens just as well with grease in there, and the weld is then thoroughly protected from future corrosion attack.
  18. Don2222 Minister of Fire
    Salem NH
    Yes, it is much better than nothing!
  19. heat seeker Minister of Fire
    Northern CT
    A few drops of oil is all I've used for decades, works for me.
