Northstar or Xtrordinaire?
FenderBender
15
Upstate SC
I have 2500 sqft down and 700 up in a bonus area. I am not too concerned about heating upstairs. I am looking at the Northstar and the two Xtrordinaires. I am thinking that maybe the Northstar and the FPX 36 will do the job and if so, I'd love some pros and cons on each of these.
I am looking to augment the heat from a heat pump...It does not necessarily have to heat the entire lower level. I have already been quoted 6400 installed on the FPX 44 and 5800 on the FPX 36. I am waiting on a quote on the Northstar.
Thanks!
Thanks!
I, ironically, am considering the same units as you are- I am looking for a replacement for an old po-s ZC fireplace & can't decide on the FPX 36 or the HNG North Star! To complicate it, I learned today that FPX is coming out with a new version of the 36 that doesn't require the blower or outside air cooling vents & can be hooked up to heat ducts.
https://www.hearth.com/econtent/index.php/forums/viewthread/72368/
that FPX 44 looks awesome. I bet it does a great job. I would think the layout of the 2500 sq ft would be the key.
I bet they can work on that price a bit too.... jmo
OK, I just got what I think is an incredible quote on the Northstar. It is quite a bit less than the FPX 36. My only concern is whether I am going too small.n My fireplace is located on an interior wall in the center of the house. At the price I was quoted, I am thinking of adding the duct work mentioned. byway any input is appreciated.
Thanks!
I have the FPX 44 and love it. This is my 3rd season with it. The POS system really does work.
Top Pro's: kicks out a ton of heat, I have approx 2400 sq, oil furnace is set to about 55 and never comes on for heating (runs for hot water) House is comfortable - we all are in shorts all winter. I love the look of the FPX - huge viewing area. Large firebox.
Con's: I struggle to get effective heat out of over night burns. I do have coals in the morning so I can start fire w/o match but it isnt pumping out heat. This is also a hungry unit - burns a lot of wood. Another mild con is the fan takes a while to kick on - others have put foil around censor to improve this - I have not tried it.
I have no regrets
I pulled the trigger on the Northstar. I had to make a decision on framing by tomorrow. The price difference was 1400 between it and the FPX 36 and I could not find enough info on the FPX to justify the additional cost. Thanks everyone for your comments and I am looking forward to my new high efficiency fireplace!
I bet you are going to love it.
