    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. NH_Wood Minister of Fire
    southern NH
    #1
    Helpful Sponsor Ads!
  2. Nixon Minister of Fire
    West Sunbury ,Pa.
    Don't really know . But , I'd suspect that it would depend on the damage done to a chain ,and how much an individual likes to make sparks . :)
  3. amateur cutter Minister of Fire
    West Michigan
    A lot if you get a dressing stone with it. I've got over a hundred on mine, & it's still got life in it. When they get small enough I switch them to the Oregon mini grinder. A C
    Backwoods Savage likes this.
  4. NH_Wood Minister of Fire
    southern NH
    Cool - thanks guys! Any thoughts on the sharpener - is there a better make/model for similar? Cheers!
  5. MasterMech Minister of Fire
    Hudson Valley NY
    Pretty good bang for the buck with that one. Cheaper is Harbor Freight ;sick and better is Oregon. _g ($$)
  6. NH_Wood Minister of Fire
    southern NH
    Yes - I think I'd like to offer a chains sharpening service for fun (and then hoping to get some basic saw servicing business, again, for fun), so I'm thinking a higher quality model, but nothing too crazy - I'm sure I wouldn't get too many chains per year. Cheers!
  7. Jags Super Moderator
    Northern Illinois
    If you think you might line yourself up for some business, get a good one that the frame will not flex (unlike the HF one).
  8. blades Minister of Fire
    WI, Milw
    A lot depends on the condition of the chains as far as the stone wheels are concerned, those that are badly rocked or been digging in the dirt are going to wear your radius off the wheel requiring frequent dressing to restore the proper shape. A little bit has to do whith the wheel itself as depending on the brand some are a bit harder than others. Harder ones hold shape better but tend to easily burn the cutters softer ones reverse.
  9. lukem Minister of Fire
    Indiana
    I have the harbor freight grinder (newer red one). Normally I wouldn't have bought it, but it was a Christmas gift. I'm pleasantly surprised with it...but I have no previous experience with other grinders...so ignorance is bliss for me right now.
    I've sharpened about 10 chains so far and they cut great...maybe not as good as a fresh out of the box chain...but really good.
    Not necessarily recommending it...just saying it isn't a waste of time.
  10. Highbeam Minister of Fire
    I use the HF one and it should last forever. I also don't dress the wheel and see no reason to do that. The shape will always be pretty close to ideal, certainly close enough to cut well.
  11. lukem Minister of Fire
    Indiana
    The HF wheels are about $5 on sale. Mine too is still holding its shape very well...so useful life isn't super important. It's not like it is a diamond blade for a concrete saw.
  12. Jags Super Moderator
    Northern Illinois
    Keep in mind the thickness of the wheel. It changes depending on chain size.
  13. lukem Minister of Fire
    Indiana
    Yup...but i only have one size to worry about.
  14. Jags Super Moderator
    Northern Illinois
    That was more for the OP and in reference to picking up a little side work.;)
  15. lukem Minister of Fire
    Indiana
    Gotcha. I think two wheels is about all a man needs for most chains.
  16. amateur cutter Minister of Fire
    West Michigan
    Even if the stone retains it's shape, it gets filled with metal filings over time & doesn't cut as efficiently, thus more heat. A C
  17. smokinj Minister of Fire
    Anderson, Indiana
    I have had the same wheels since 2007 and they we used whenI got those. I always use kool grind and feel like it helps with wear and tear on the wheel as well.
  18. fabsroman Minister of Fire
    West Friendship, Maryland
    I just bought the Northern Tool grinder. Had to send the first one back because one of the screw holes was not tapped. Have not used it yet other than to turn it on, but it looks solid and feels solid. Need to find someplace to mount it to. Don't know if the Oregon one at $200 more is really worth it unless you are grinding a ton of chains.
  19. MasterMech Minister of Fire
    Hudson Valley NY
    Funny, after running a file over my chains, they cut better than a NIB chain.... ;)
