    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. briv New Member
    Connecticut
    I was going through my normal routine last night of moving around the coals before loading up the stove for the night. For some reason I grabbed the shovel from my fireplace tool set instead of the poker. Started moving the coals around and suddenly the shovel was on fire and letting of nasty, nauseating fumes. "Oh, bleep!!" There was a moment of decision making and I almost (I said almost) ran through my house with a flaming shovel to throw it outside (probably would have ended badly). Instead I quickly unscrewed the handle which gave me just enough room to put the shovel entirely in my stove and close the door. Ran outside and grabbed the bucket of water I keep next to my outdoor fireplace, brought it inside, pulled the shovel out with my welders gloves and dumped it in the water. No major crisis but hair raising none the less.
    #1
    Helpful Sponsor Ads!
  2. Stubborn Dutchman Member
    Southern Michigan
    Pretty quick thinking, I'd say. Glad there was no damage done to you or your home.
  3. Jags Super Moderator
    Northern Illinois
    On a positive note, there isn't any paint left on it to burn now. ;-)
  4. mikepinto65 Minister of Fire
    Webster, MA
    Maybe he used a wooden shovel :lol:
  5. Bub381 Minister of Fire
    Mid-coast Maine
    Good point. :red:
  6. LLigetfa Minister of Fire
    NW Ontario
    Never heard of a flamable shovel. Must be an ornamental set not intended for real use.
    I often use the shovel along with the poker when I have some challenging rearranging to do. Also, before I made a coal rake/ash hoe, the shovel did the job.
  7. oldspark Minister of Fire
    North West Iowa
    I'm glad somebody brought it up cause I was wondering myself, one forum member had a cheap shovel and the paint started on fire and he had to throw it outside, it was a funny post.
  8. Bub381 Minister of Fire
    Mid-coast Maine
    No need for name calling.ASH/HOE.Just joking.
  9. WoodpileOCD Minister of Fire
    Central NC
    :lol:
  10. BrotherBart He Who Moderates
    Northern Virginia
    That would be me. :grrr:
  11. briv New Member
    Connecticut
    I knew I shouldn't have used the plastic shovel from my summer sand castle set. ;)
  12. pastera Feeling the Heat
    SE Mass
    Been there - done that with a stove too small to stick the whole thing into
    Just explain the nasty smell to the wife and move on - Nothing to see here folks
  13. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    Well now that you've burned off the paint you should be good to go from here on in . . . did that with my shovel in the first season . . . caught it on fire I mean . . . I pretty much just let the paint burn off before pulling it out . . . it has bee fine since then.
  14. Backwoods Savage Minister of Fire
    Michigan
    Hum.... Never had a shovel catch on fire before. That must have been an eye opener!
  15. SnapCracklePop Feeling the Heat
    Southwestern Penna
    "Also, before I made a coal rake/ash hoe, the shovel did the job."
    {perking up; sitting on my hind legs}
    Pix? Parts list? Assembly directions?
    As someone once said, pix or it didn't happen...
    Nancy
  16. LLigetfa Minister of Fire
    NW Ontario
  17. That avatar pic is hilarious by the way. Hasselhoff is an icon in Germany. Back to the thread. Yes, very quick thinking. My stove is on ceramic tile out to the door, so I could just run outside and have, but I'm still not sure how that paint caught fire and why they would sell that shovel if it was easily flammable.
  18. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    Maybe they figure most folks will only be using the shovel to clean out cool ash . . . or maybe it is cheaply made? In any case I suspect you will find that you have no more issues with that shovel.
  19. I bought a cheap set of tools and they are metal. Wood has no place near a hot stove except that which is fuel.
  20. BrotherBart He Who Moderates
    Northern Virginia
    Person make shovel no understand Engrish and no read about combrustibles.
