old smoky
racedad
4
new hampshire
hello all, i have a p38 , last winter i had to put the upgrade cir.board in it, ive had nothing but problems sense,i've had to replace esp probe 3 times (3 blinks), very dirty smoky burns lots of resido,and twice it has filled the house with smoke coming out of the hooper, and ideas on this problem
Sounds like your combustion fan is not working or the exhaust pipes are plugged
When was the stove and chimney given a full cleaning ?
From what you are describing the fire is not getting enough air .
I really don't know your stove but expect someone
who does will be along shortly good luck
Have you cleaned the combustion fan? Often they get an ash build up on the blades, which can significantly reduce fan efficiency.
Dave
