We are located in north central Illinois and our house is a late '60s built, 1500 sq. ft., single story (8' ceilings), fairly open layout and we are planning on installing either a Castine or an Oslo.
The house is currently heated by radiant electric ceilings and we would like to lean away from using it except if/when needed in the bedrooms and more toward using the stove for our heating needs. We like things a little cooler so we keep the thermostats around 63-65 degrees. We are also adding more insulation to the attic space to bring it up to date (also to take advantage of energy tax credit with a stove purchase). The house is 2x4 construction and insulated to 1960s standards, windows are excellent shape single pane with good storms. Basement is getting hydronic under a floating floor since there is no residual heat from any appliances (all electric house).
Based on the the specifications I've found, the Castine should meet our needs. In researching the two models, I see a trend to go with the larger Oslo for over night loading and more convenient 24/7 use. I have not found too much information by Castine owners so I have come here to get more opinions and experiences. Any help would be appreciated.
thank you
thank you
