Osburn 45 MF over heating
chumlee Posted By chumlee, Dec 18, 2010 at 4:14 PM
Thread Status:
  1. chumlee
    chumlee
    New Member 2.
    NULL
    Dec 18, 2010
    1
    0
    Loc:
    New Mexico
    Hello all! Hoping someone can help me out with my problem. Just installed an Osburn Hybrid 45 MF pellet stove. I will light it and it runs ok for about 20 minutes and then it will stop feeding pellets, turn off give the O code, which according to the manual is overheating. Does anyone have any ideas as to why this might be happening.
    Thanks,
    Chumlee
  2. SmokeyTheBear
    SmokeyTheBear
    Minister of Fire 2.
    NULL
    Nov 10, 2008
    13,363
    1,662
    Loc:
    Standish, ME
    If the convection fan doesn't start or is failing (or the convection air path is blocked), most pellet stoves will quickly overheat unless they are at a very low setting.
  3. dave1966
    dave1966
    Member 2.
    NULL
    Aug 24, 2008
    68
    0
    Loc:
    south jersey
    i had same problem was the over heat safety switch replaced ran fine
  4. pete324rocket
    pete324rocket
    Feeling the Heat 2.
    NULL
    Nov 11, 2007
    472
    6
    Loc:
    albert county, new brunswick
  5. Fsappo
    Fsappo
    Minister of Fire 2.
    NULL
    Apr 9, 2008
    4,331
    181
    Loc:
    Central NY
    Try jumping the limit switch. Could just be a bad switch there. If the switch does turn out to be the problem, dont continue using the stove, shut it down and replace the part first. I'm assuming this is a new stove? If it is, I would have the local retailer you bought the stove come out and look at it. If it was just installed, even the snap disks etc, should have a 1 year parts and labor warranty.
  6. pete324rocket
    pete324rocket
    Feeling the Heat 2.
    NULL
    Nov 11, 2007
    472
    6
    Loc:
    The microprocessor of the stove is giving the error code of what it "sees". This would be the result of "input to its sensors". Similar to all S.B.I. stoves. When people give advice ,do they really know? or just pretend to know?
  7. SmokeyTheBear
    SmokeyTheBear
    Minister of Fire 2.
    NULL
    Nov 10, 2008
    13,363
    1,662
    Loc:
    Standish, ME
    Correction, the microprocessor is giving an error code based upon what some human says it sees. The error code could also be the result of a bad microprocessor or "ppp" (piss poor programming) or a bad sensor.
    ETA: Or the controller is correct and the sensor did indeed see an over heat condition.
Thread Status:
