Hi guys, I hope to garner some accumulated 'wisdom' with this situation. Someone recommended to weld or place a 1" or 2" piece of metal in the flue to restrict the air flow.
Also, If the unit has a 'pilot' (typically inside the firebox, just below the door a few small holes to aid in fire startup) blocking it with foil will also help.
Do you have any other suggestions that has helped you in the past?
