owb?
rdzracing
8
michigan
i'm building a owb out of propane tanks. just wondering where the return water should come back into the tank at? Also should i take the hot water off the top of the tank.
thanks for your input
Odds are that if you are asking these basic questions, you need to do a LOT more research before even considering building an OWB.
I don't know where the in/out should be exactly, but I'd imagine cold on the bottom, hot at the top like an oil boiler. Are you planning on having anything for secondary combustion or is this going to be a smoke dragon?
Taking hot from the top & return to the bottom is the most eff way to plumb a boiler
Think the confusion maybe from the lack of description of your intended design
As typed it sounds like a barrel in barrel stove (not sure if thats what you want to build) as it would produce a lot of smoke
