I'm ordering a a full cord. According to the guy itDoes the basement include the 1100 sqft and is it insulated? How far is the fireplace from the stairwell? How much fuel (oil, propane etc.) did you use last winter for heating (especially during the coldest months)?
Do you already have some dry wood?
Will the insert be trying to heat the entire house and is the total including the basement 2200 sq ft? Note that a lot of heat is going to be lost through the uninsulated walls. This can lead to a lot more wood consumption, up to a third more wood!
I used about between 18 -20 Mcf N-Gas per month jan-March are the coldest. The basement is not insulated. I just installed dry wall vapor barrier. 1100 sf basement as well , it a ranch house the fireplace is in the middle of the basement room, and is 17ft from the middle if the stairwell.
I ordered wood one full cord in August , the guy said 1-1-5 year seasoned
Also the Neo fires E-W as opposed to the summit N-S? Would this make a difference as well ?
The quotes seem pretty low when including install. Is a full liner part of the quote?
Given your heat load, I would go with the biggest insert you can fit in there. If price is an issue maybe the Osburn 2400 would be a cheaper option for a large insert.
Most people prefer N-S loading as you can fit more wood in the same size firebox, less risk of logs rolling against the glass, and you don't have to reach in the back of the firebox. However, E-W loading is giving you slightly longer burn time.
