    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. raybonz Minister of Fire
    Carver, MA.
    According to the owners manual the firebricks are 9"x4-1/2"x 1-1/14" but when I tried to fit 2 replacement TSC bricks in they would not fit with 2 bricks side by side. I measured the pumice bricks I removed and found they actually measure 4-3/8" wide VS the claimed 4-1/2" and the TSC bricks were dead on.. I ended up grinding ~1/16" off of the TSC bricks with a masonry wheel in my angle grinder and they fit great now. Now I have the back of the stove lined with 3 of the hard TSC firebricks and saved one of the pumice bricks for side or bottom use where they are not subject to impact :)
    Ray
    #1
    Helpful Sponsor Ads!
  2. HomeBruin New Member
    Califon, NJ
    Good thing you had a grinder. Still sounds like a PITA. Maybe the bricks that had been seasoned through use in the stove shrunk? But then they would have been looser fitting in the stove. Weird. When I was looking at the Alderlea, the sales lady said it would be easy to replace the bricks because they were a common size.
  3. raybonz Minister of Fire
    Carver, MA.
    Pumice definition: A light, porous, glassy lava, used in solid form as an abrasive and in powdered form as a polish and an abrasive.
    I seriously doubt this stuff will shrink and feel that the 4-1/2" is not really that measurement.. I had 2 perfect 4-1/2" bricks and they would not fit in the space that were occupied by the pumice bricks.. BTW the hard bricks work fine and should withstand abuse much better.. Grinding them down took 2 minutes and easy to do. I clamped 2-4" wide boards on both sides of the brick and resized them..
    Ray
