Recently my stove was sitting pretty at 8-900 and not matter what I did it was just running like that..
Called pe and they said it was ok but 900 n up for long periods aren't good...850 and down fine...
Anyways, checked gaskets and all of our tech stuff and still couldn't get the stove temp down... keep in mind this is an insert and these were readings from the front of the stove...
Thought I was reloading to high ... Reloaded at 250 - same result... didn't take a genius to figure its getting air from somewhere right?.... found it (i think)
EBT!
here is what I think happened...- ash, I hate it. I was moving coals and packing ash with the shovel.. to the point that my ash pack was higher than where the air manifold was! It was 1.5 buckets that I finally took out..
By the ash being so high the coal bed was often higher to the point some would fall out if not careful when opening...I would fit about 7-8 good size pieces but not large .. there wasn't enough space..
My theory is the ash was so thick it insulated the bottom of the stove not allowing ebt to sense the hot fire and close... instead it stayed open all the time .. so even when the air was closed it was still giving the extra air...
I might be totally wrong... but since I removed the ash and kept it at a much lower level the stove is much more easier to keep at more reasonable temps... and doesn't go anywhere near 850+ .
All of my wood is 2+ years and comes inside for a couple days before being burned - so yes its dry
Moral of the story ... clean your ash out within reason and looks like ebt works
EBT!
