PE Super 27 stove to DVL
MDWOOD
46
maryland
Hi all been lurkin awhile and yesterday go my new super 27 Heritage home.
I plan on changing my single wall pipe thats on my existing stove to Duravent DVL.
Will a single piece of DVL slide over the flue collar on the PE stove?
Not sure if i need the DVL-Adapter or not.
Thanks Bill
PS; forgot to say that all i've been hearing is a big sucking sound since im not burning now (Frigid here)
Must be the oil burner suuuuuuuuckkkk
When I did my duravent dvl install for my Pe27, I used the adapter, and it worked as intended. I didn't try using a regular section of pipe directly to the stove collar, so I cant comment on that. If you haven't considered it yet, I would get a telescoping section. It made my install a lot easier. Best of luck.
Not sure if the flue collars are the same but on the T6 stove DVL pipe slips directly on the flue collar.
I used the DVL adapter when hooking up my 27 Heritage. Didn't try to see if it would fit without the adapter.
