PE True North TN19
RiverLogger
61
Western Oregon
Okay, I have done all the searching I can and I started a few conversations with people here that have this stove but am reaching out as far as possible for reviews on this stove.
Here are my concerns:
Draft/Air intake adjustment lever seems cheesy and thin metal.
Actual door opening seems small.
Will I get overnight burns? (I currently do with my 13NC)
How do you get dust from chimney sweep off the ceramic board covering the baffles? (from looking at the stove it seems the airwash tubes are not removable?)
Thanks all for the input. I'm 90% sure this is the stove I want, I just have these concerns.
The draft mechanism is the same one used in all PE stoves, and has proven itself to be pretty bulletproof.
The door opening is plenty big for North-South loading, which is how the True North is designed to burn.
The True North will easily hold a fire all night.
Baffle removal instructions appear on page 6 of the manual at http://www.chimneysweeponline.com/pemanualtruenorth.pdf
Thanks for the information and the baffle removal instructions. I really like the specs on this stove.
