Pellet Insert in new construction, Help? Need some info from those who have done it!
Catfishjack
86
Northern NY
We have had a St Croix Prescott EXL for the past three winters and have loved it. But..all good things must come to an end.
My wife wants to in a Pellet fireplace now and take the free standing stove out. I cannot find any information anywhere
on the installation of a pellet fireplace insert into new construction.
Insert will more than likely be a Harman Accentra unless I'm talked into something better by someone here on this forum..
Do I need a Firebox?
Any Links you know of where I can see some pictures or information in what this will take.
Many Thanks
Many Thanks
Harmon makes a zero clearance kit that allows you to install this unit but you need to research everything about how to instal and where you plan to put it in because there are pitfalls along the way. I did the instal and dropped info and pics here you can search for it and see but if you are serious then it is some work to get correct and you MUST know exactly what you want for looks before you start as everything from the thickness of the tile or stone for the facia to the heigh of you hearth. You will need to know and understand exactly how high you want the exhaust outside so that you han build your headers high enough, then you need to fit everything and make sure you are plumb and level before you even install the Accentra unit.
You can IM if you want specifics...
Rick
