Pellet install
Biglumber Posted By Biglumber, Jan 24, 2008 at 12:49 PM
Thread Status:
  1. Biglumber
    Biglumber
    Member 2.
    NULL
    Jan 19, 2008
    73
    3
    Loc:
    Colorado
    I'd like to seal the thimble gap(area between the thimble and the pipe passing thru) with something to block the draft coming in the house. I'm using pellet-vent double wall(simpson).
    Any recommendations?
    TIA
  2. BignBeefy
    BignBeefy
    Member 2.
    NULL
    Jan 21, 2008
    61
    0
    Loc:
    Sandown,NH
  3. HD41
    HD41
    Member 2.
    NULL
    Jan 11, 2008
    174
    6
    Loc:
    Northern Ohio
    I found painters caulk is adequate to seal edges of the wall plates to the siding outside, drywall inside and for inlet tubing, minimal heat in these areas. Suggest High temp silicon sealer available at hardware and building supply stores for the double wall exhaust pipe to the wall plates. No need for anything like furnace cement as with wood burning stoves. As a temporary stopgap I stuffed some aluminum foil seal around to the pipe because that is what I had.
  4. pete324rocket
    pete324rocket
    Feeling the Heat 2.
    NULL
    Nov 11, 2007
    472
    6
    Loc:
    albert county, new brunswick
    Seems to me I was going to buy special fireproof packing material but realized it wasn't that hot and used fibreglass insulation packed tightly since loosely doesn't stop any air-assuming you mean between pipe and thimble.Someone say so if this is bad advice but it works for me.
  5. jtp10181
    jtp10181
    Minister of Fire 2.
    NULL
    Feb 26, 2007
    3,729
    3
    Loc:
    Madison, WI
    Use black silicone caulk. That will withstand the heat the best.
  6. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,102
    Loc:
    madison hgts. va
    the area between the pipe and the inside of the passthrough thimble were not intended to be filled, this is a standoff for the clearance to combustibles for the pass through of the pipe. better to seal the seams around the pipe inside and out with high temp rtv, i would strongly suggest contacting simpson duravent and checking before inserting any materials into that void. number for their tech line is 800-835-4429, or e mail them via the contact us at www.duravent.com
  7. Biglumber
    Biglumber
    Member 2.
    NULL
    Jan 19, 2008
    73
    3
    Loc:
    Colorado
    Thanks guys. I won't be rock wooling the thimble. Any ideas where I can find this high temp rtv?
  8. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,826
    9,891
    Loc:
    Northern Virginia
    Lowe's and Home Depot in the caulk department. ACE Hardware back with the stove pipe stuff.
  9. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,890
    8,631
    Loc:
    South Puget Sound, WA
  10. Biglumber
    Biglumber
    Member 2.
    NULL
    Jan 19, 2008
    73
    3
    Loc:
    Colorado
    BeGreen, Thanks for the tip.
Thread Status:
