    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. myers7457 New Member
    central pa
    We bought an ecotec in october 2011. We like the stove and it heats the house. I like the fact that you can run it from onboard tstat and it shuts off or it runs and drops off to minimum. The problem we have had is the cleaning required. I have nothing but good things to say about the dealer. It was dealer installed. He has back many times to try and get it set up properly. The stove is basically needed to have a complete cleaning on a monthly basis(sometimes more). We use only the pellets that the dealer suggested. The dealer has suggested we switch to a quadrfire classic bay 1200. I was just loooking for thoughts on ecoteck or quadrafire.
    #1
    Helpful Sponsor Ads!
  2. SmokeyTheBear Minister of Fire
    Standish, ME
    What were you running through the stove on a monthly basis?
    What brand of pellets was it?
    Pellet stove cleaning is all driven by ash levels produced and that varies by pellet brand, type, and a host of other things.
  3. Sweets Guest
    Finally someone cleaning stove often
    Like I do..
  4. myers7457 New Member
    central pa
    They are green team out of Pa. I have burnt 2 tons and started on the 3rd. I started burning these part way through last year. I tried other pellets but it was worse. The dealer says we shouldnt be cleaning it this often.
  5. SmokeyTheBear Minister of Fire
    Standish, ME
    Lets see if I have this right you started burning on the 3rd (of what month and year please) and you have put two tons of Green team through the stove since.then.
    Two tons is enough for two good complete cleanings on a lot of stoves plus the normal weeklies.
    Would you please describe the flame (color, activity, etc.) and how the stove was installed venting starting at the stove and going to and including the termination cap. Size, lengths, orientations, and angles of all elbows along the nature of the insulation and air sealing (tightness) of your house and any other air movers in the house that move air from inside to the outside?.
  6. Sweets Guest
    Damn , that's a lotta info u need , no
  7. DexterDay Minister of Fire
    NE Ohio
    The Ecoteck is a great stove, but has numerous different controls. The Classic Bay is a Great Heater with just 3 heat settings. Set to desired temp, then select heat range, Bam. Heat. Easy Peasy.
    There are a few Ecoteck owners on here now, give them time to chime in (Lake Girl, Bio-Burner)
  8. Sweets Guest
    Get the wisewaypelletstoves and be
    Done with it...
  9. DexterDay Minister of Fire
    NE Ohio
    Not really... if you want a good diagnosis? That's what people here are best at?
    The more info and pics, the easier and faster a result may come up.
    343amc and SmokeyTheBear like this.
  10. SmokeyTheBear Minister of Fire
    Standish, ME
    A lot of stove burn issues are caused by a messed up installation or not considering the entire house and stove as a system.
    DexterDay likes this.
  11. Sweets Guest
    It must be the pellets your dealer
    Providing..
  12. Sweets Guest
    Yeah it's the stove set up , everybody
    Blames the pellets
  13. DexterDay Minister of Fire
    NE Ohio
    Greene Team is a Very Good pellet.
    Have you tried any?
  14. Sweets Guest
    Maybe it needs drafting or something
  15. SwineFlue Member
    NE Pa
    I think the OP meant they have started on the 3rd ton... since last year.
  16. SmokeyTheBear Minister of Fire
    Standish, ME
    Sweets, there could be a lot to that needs drafting as in combustion air flow but without "all of that funny information" I was asking about we may never find out and the OP just might find out that a new stove of any kind isn't the answer at all and still produces the same situation..
  17. Sweets Guest
    What pellets????
  18. Sweets Guest
    I like when you call me sweets ,it sounds funny.
  19. Sweets Guest
    Sorry guy , I'll take a back seat..
  20. Sweets Guest
    I think the problem is your dealer , he's trying to sell u another stove +tells you to stay with
    Those pellets , try a better brand of pellets , pa pellet have high ash content
  21. Sweets Guest
    Call ct pellet , he'll give you different bag to try .
  22. Sweets Guest
    I don't think there's a problem with 2010
    Stove installed by the dealer
  23. Sweets Guest
  24. DexterDay Minister of Fire
    NE Ohio
    Huh? CT pellet is pretty far away? Not exactly sound advice, for someone truly looking for help?
    Greene Teams are a good pellet. After 2 tons, its likely ash is built up in the works, intake has become clogged, EVL isn't correct (yes, some dealers mess that up).
  25. Sweets Guest
    I'm sorry , I thought you were from ct.
