    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. N.E S4 Member
    I'm new to pellet stove. I just picked up a used Englander 25-PDVC.
    I installed this in my basement, I run it at 6,6 it seem to be burning a lot of fuel in 5 hours. I only use it when I'm home after work.
    I would like to know what's the best setting that's everyone using for the best efficiency. The 3 buttons at the bottom do you keep it at factory setting or do you have your own setting.
    #1
    Helpful Sponsor Ads!
  2. dale hallamn New Member
    Oxford ct
    I put mine on a thermostat and set a temp for the room and it just does its own thing with feed rate depending wether the tstat is calling or not and seems I've saved a lot of pellets as for the 3 buttons I've only played with them to get what ever pellets I'm using to burn better
  3. Pweeny New Member
    Pennsylvania
    We just installed one of these new about 2 weeks ago. We burn a hopper full (3/4 a bag) in about 8-9 hours at setting of 1,3.
  4. N.E S4 Member
    Last night the stove went out with E-1 code when I was trying to raise the temp I had it set at 7 and 9. I took the side panel and back panel off found out the previous owner had removed the combustion fan housing. 1 screw was broken and 2 other screws was not tighten this cause the vacuum leak at high temp setting cause the stove to shut off.
    I drilled out the broken screw installed a new gasket, set the lower setting to 3,2,1. Now the stove's burning very well. Next I'll be replacing the bearings for the convection motor and exhaust motor.
    With just 1 week of ownership I've taken this apart this stove twice. I think I'm an expert now.
  5. SmokeyTheBear Minister of Fire
    Standish, ME
    Not so fast Grasshopper, the birds await.
    Pweeny likes this.
  6. N.E S4 Member
    Expert in taking it apart
  7. Pweeny New Member
    Pennsylvania
    You are certainly on your way!! I plan on taking mine apart for its first weekly maintenance tomorrow. Weeeee!
