Pellet stove pot over flowing
Noseworthy27
5
Newfoundland
Hi I have a timberwolf tps 35 pellet stove and the stove burns fine on low only there isn't much heat and small flame and if I turn it on the 2nd setting or higher it leaves unburned pellets in the pot causing overflowing anyone have this type of stove no of a fix
I'm not familiar with your stove but use Google and the search bar here and type in your issue. Giving you a bump so someone that can help will possibly see this post. Is there a temp setting separate of your feed setting? Is your stove clean and getting enough air for the bigger burns?
