Pellet Stove Recommendations
claybe
370
Colorado
Can you guys and gals recommend some stoves to look at? I would like to add a pellet stove to my future master suite which will be around 400 square feet. I would like auto light and temperature control and something the wife will like to look at! Thanks.
First off, all manufacturers warn against installs in sleeping areas, I'm not sure why, I sleep in my living room with the stove in it. Second You probably would want a small unit if you only wanna heat 400 sq. ft. even then it will probably be a low burn all the time. St. Croix Element, Harman P38 or maybe Accentra, Enviro Mini. just to name a few. Good Luck
If you can afford it ,..go with a Harman.
Love My Harman! I feel my P38+ would cook that 400sqft room though
