    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. mtalea New Member
    Bristol, Connecticut
    Hello,
    I am extremely new to pellet stoves etc; My question is, can a pellet stove be installed into a single flew(not sure of spelling) chimney and share air space with boiler?
    If the answer is "yes" does it require a stove pipe be installed all the way up to above chimney top?
    thanks for any help and ideas offered.
    I was thinking of venting horizontally out a wall,if chimney is not applicable
    Any thoughts of that?
    thx
    #1
    Helpful Sponsor Ads!
  2. Corie New Member
    Halifax, VA
    single flue? as in venting the pellet stove into the exact same flue that the boiler is using?
    If that's the case, it's a no go. No two appliances can legally connect to the same flue.
    Venting horizontally out the wall is usually the easiest way to do things and requires the least amount of work.
  3. mtalea New Member
    Since we are in the same climate,u in PA and me in CT. what recommendations do you have for thru the wall installs.?....parts and such?
    thx
  4. Corie New Member
    Halifax, VA
    it's all relatively the same. pellet pipe, pellet pipe thimble, and then some type of termination cap that keeps birds out.
    If someone doesn't beat me to it, i'll get ya part numbers later, i'm studying right this minute :(
Thread Status:
