pellet stove wont shut off until empty
nedski7
3
connecticut
Hello all
i acquired a house with a whitfield 11-tc.
I cleaned it went through it, fires and burns nice,all the controls work, i can stage up and down the flame and the blower but it wont shut off with the thermostat.. When the thermostat is satisfied the flame reduced down to about half and keeps throwing heat and wont fully shut down until the hopper is empty.when i disconnect the t-stat same thing and there is about 10 volts across the t- stat connection terminals . i also noticed the second the stove starts the hot air blower motor turns on even before the stove is lit thinking possibly an issue with the low limit switch.. but i dont know exactly how this stove should operate..is this normal?????
I don't have a thermostat, I shut mine down by turning the pellet feed off, The fire dies and the fans continue until the temperature falls off.
Both the convection fan and the combustion fan run whenever the stove is operating.
Dave
Dave
So the fans always run together?? as soon as you turn it on while the pellets are heating up prior to the actual fire starting, the convection fan is On???
