Ok for those of us that have the pf100 you know that its manual on the everyday running of the furnace is less than helpful. Well I finally got a few days off work and had the chance to figure this out. So here it goes, feel free to add comments or corrections.
The thermostat tells the furnace to turn on once the temp drops 3 degrees under the desired setting. The furnace then goes into a minimum burn that is determined by the feed rate. If the desired temp can not be constantly held then the feed rate needs to be increased. If the feed rate is to high then you will use more wood pellets then needed. This will vary greatly due to the size of the area that is being heated and the climate of the zip code you live in. The furnace will stay in the minnimum burn stage (determined by the feed rate setting) until the room temp becomes 1 degree over the desired temp then the furnace will let itself burn out.
If anyone is interested I will try to calculate the amount of increase in lbs of pellets per setting in the feed rate. In using my furnace as the control I'll have to wait for it to get colder in my area to get accurate information.
Having correct information is only 20% of solving a problem, the rest is deducing the information correctly, and executing the solution correctly.
