SmokeyTheBear
Belay that bang on order if there be cast components in that stove. One sharp blow in the right place and they are history.
SmokeyTheBear said:Belay that bang on order if there be cast components in that stove. One sharp blow in the right place and they are history.
macman said:SmokeyTheBear said:Belay that bang on order if there be cast components in that stove. One sharp blow in the right place and they are history.
Yep...sorry that I forgot to add that....only bang on STEEL. If you're not sure what you have, don't do it at all.
Thanks Smokey!
SmokeyTheBear said:macman said:SmokeyTheBear said:Belay that bang on order if there be cast components in that stove. One sharp blow in the right place and they are history.
Thanks Smokey!
Anytime macman, every time I see or hear of the use of a hammer around heating devices. I remember how we used to make certain that no one could use old cast radiators that were past safely being able to handle pressure due to rust or pulling old cast piping out of buildings as salvage weight.
smokey thanks, it is very easy to clean, as i do use some brushes for the fan blade behind ash bin......just curious, always lookin for another one of those unique ways of getting it cleaner....thanks againSmokeyTheBear said:Nope, never seen one up close, except at a stove shop and the sales folks really didn't want to talk gritty detail. Try getting a sales droid to discuss cleaning a stove sometime.
Some of those Harmans open right up from what pictures I've seen. A nice simple set of brushes and a vac is likely all that is needed. I tend to keep it simple and have found that brushes with flexible shafts for handles do a good job. As does a cloth and a short length of wire. My stove doesn't have any really difficult areas to get to for ash cleaning. But playing with the convection blower is a knuckle skinner and requires contortionist abilities.
I reserve hammers mostly for nails.
almost 100% sure that #3 is a plus 20% setting and #2 is a negative 10% and 1 is standard will have to check my tech manual tomorrow to be sure.wrkinonfire said:The control box is set to #3= -20%. The pipe is vented directly outside. The staining is rescent and is most likely from me loosening it up to clean it so much. I am taking the pipe all apart and cleaning it today, removing the pot, removing all of the inside cast pieces. Cleaning eveything. Replacing the gasket under the firepot.. Hope this helps. I bought 12 bags of Drycreek yesterday. I'm up to $1460.00 so far on heating this winter. It's 56* in my house. Few more months....
https://www.hearth.com/econtent/index.php/forums/viewthread/51942/SXIPro said:Well, DAMMIT, don't keep us in suspense...what was the cure?
no pane said:https://www.hearth.com/econtent/index.php/forums/viewthread/51942/SXIPro said:Well, DAMMIT, don't keep us in suspense...what was the cure?
