Pneumatic transfer system
Bill Bennion Posted By Bill Bennion, Aug 11, 2010 at 1:53 AM
Thread Status:
  1. Bill Bennion
    Bill Bennion
    Member 2.
    NULL
    Feb 2, 2009
    59
    0
    Loc:
    Lee, NH
    Has anyone used pneumatic transfer for wood pellets? I have a Nutone three stage whole house vacuum system that I would like to use as the power source for a transfer system from a 7 ton silo to my PB 105 or at least to an inside bin. Could I use a Corn-Vac for this or just a sealed bin with slide gate.
  2. smwilliamson
    smwilliamson
    Minister of Fire 2.
    NULL
    Dec 28, 2009
    4,501
    782
    Loc:
    Southcoast, MA
    I sure would like to help you out here. I have been behind a few of these homemade jobs. It's really not that difficult. A 30 gallon metal trash can is ideal. You do not want to hook up to the unit itself unless you can seal off the air from the hopper toward the burn pot. Things get messing when you introduce all that pressure with nowhere for it to escape to. You want to use static free hose. You need an air feed and an air return and a proximity switch to open the circuit when the can is full and a toggle switch to turn it off when you are emptying the bin. Depending upon the size of the motor you should be able to go about 50 feet or more.
  3. smwilliamson
    smwilliamson
    Minister of Fire 2.
    NULL
    Dec 28, 2009
    4,501
    782
    Loc:
    Southcoast, MA
  4. smwilliamson
    smwilliamson
    Minister of Fire 2.
    NULL
    Dec 28, 2009
    4,501
    782
    Loc:
    Southcoast, MA
  5. peakbagger
    peakbagger
    Minister of Fire 2.
    NULL
    Jul 11, 2008
    2,800
    617
    Loc:
    Northern NH
    One thing to be very aware of is static electricity for a homebuilt system. The movement of the pellets through the hoses will generate static and if you dotn bleed it off, sparks will occur.
    Granted the pellets probably wont catch fire with a spark but the fines that inevitably are in the mix will. The entire path of the pellets from begining to end needs to be grounded in one continuous path. If you look around on the web for grounding dust collector systems, (whihc are even more notorious for fires), there are a lot of good suggestions. Do note that even though plastic piping is tempting its a bear to ground.
  6. Bill Bennion
    Bill Bennion
    Member 2.
    NULL
    Feb 2, 2009
    59
    0
    Loc:
    Lee, NH
    Is the return line necessary? I am worried about introducing warm & potentially humid air into base of silo(freeze potential in winter).
  7. Bill Bennion
    Bill Bennion
    Member 2.
    NULL
    Feb 2, 2009
    59
    0
    Loc:
    Lee, NH
    I was planning on using 2" electrical conduit with larger radius bends wrapping pipe with copper wire and adding short screws at intervals in pipe to pick up and dissipate interior static.
  8. smoke show
    smoke show
    Guest 2.
    NULL
    check the links i posted.
    tons of info over there.
    sounds like your doing good so far.
    maybe even post your question there.
    lotsa folks over there moving pellets or corn.
Thread Status:
