Power back-up
canuck_22
259
Ontario, Canada
DO not know the brand,but specs look more than safe for stove(or pc so you can tell us when power out!:)) group 24 battery is a smaller size,but if price is right,just get more.But looks like the inverter does not have a built in charger?
Hum...you bring up a good point...thank you so much and I will make sure to ask.
Cheers
Cheers
I use a 1200W APC with a pair of 90AH marine batteries wired in to give me 8 hours of stove runtime in a power failure.
Is this an APC as in a computer ups? it can charge big batteries like that?
Yes it can, it can take several days to do so depending on how depleted the batteries are. I have a proper marine battery charger that I will use if the batteries have been used up a significant amount.
Good to know, I have a Pro 1500 on it now, just need to rig up a battery.
How do you decide if the APC is likely to burn itself up before you let it recharge the big battery?
- Jeff
Well I just tested my APC Pro 1500 by yanking the plug, stove goes into auto shutdown mode by pulsating the fan, I'm happy with that:cool: Thank You Harman for making it this simple.
- Jeff
I've tested it multiple times by running the batteries down and letting the APC charge it up with no problem.
The marine charger is just a way to get the batteries back to capacity alot quicker.
Good to know, thanks. I've been back/forth on an APC or Tripp-Lite, finding the APC with slightly better efficiency but significantly more expensive replacement batteries. If that charging circuit is good enough to not torch itself charging your big batteries, that makes a difference on using a different battery when the original croaks.
Cheers,
- Jeff
