Proper flame Height for a Mt Vernon AE and other settings.
Deed Posted By Deed, Jan 2, 2008 at 8:19 PM
Thread Status:
  1. Deed
    Deed
    Member 2.
    NULL
    Dec 22, 2007
    57
    0
    Loc:
    Central Me
    I've been wondering what the proper flame height should be and consideration for setting it to a different setting. The Mt Vernon AE was purchased new on 12/04/2007, it has been working great. The flame height is presently set at "0". I have option of -5 to +5.
    Hope someone can give me more information. As I have read the manual which doesn't explain why I would need to change it. I may not be getting all that I can out of this stove at it's present setting.
    While I'm at it I also have the temp deferential set at 1 during the cold days and 3 when it isn't so cold. I live in Central Maine we have had a colder then normal Dec and are looking at sub zero temps the next two days. Appreciate the impute.
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,918
    8,634
    Loc:
    South Puget Sound, WA
    Use the manual mode to set the maximum flame height when the thermostat it set to high. The flame should be bright and about 8" tall. Normally this only needs to be set once as long as the same brand of fuel is being burned. Readjust if you change pellet brands. Set stove back to automatic after setting the flame height.
    Normally one would set the temp differential to a larger setting for very cold weather. I would try a setting of 2 or even 3 for the very cold weather. It will stop the stove from cycling on/off constantly. A setting of 1 would be more appropriate for mild weather (above 35 degrees). But depending where the thermostat is located, it might be better to leave it at 2 if you find the stove short cycles when set to 1.
    The reason is the differential setting is the swing between the heat satisfied point and the needs heat temp as detected by the thermostat. In very cold weather the house is going to lose heat much more quickly. This can be compensated for by increasing the temp differential. Too small a setting will have the thermostat turning on the stove a very short time after it has stopped (temp satisfied).
  3. stoveguy13
    stoveguy13
    Minister of Fire 2.
    NULL
    Dec 15, 2006
    984
    27
    Loc:
    CT
    On the Ae model the flame should come out of the pot and make contact with the center of the baffel the flame should roll up past the top of the baffel plate it is desinged to be taller then most.
  4. jtp10181
    jtp10181
    Minister of Fire 2.
    NULL
    Feb 26, 2007
    3,729
    3
    Loc:
    Madison, WI
    The flame height adjust is really for different fuels from what I understand, the automatic mode will not change that setting at all, so normally you can leave it at 0. Some pellets you might get taller flames some smaller. Stoveguy pointed out about where the flame should be on the heat output 5 setting in manual mode, if it is lower or higher adjust the flame height setting accordingly.
Thread Status:
