Proper Pipe Sealing
Chris04626
What and where are you supposed to seal the pellet stove pipes.
I have an adapter thats on my stove that goes to a 90 degree elbow that goes into a 2 foot straight pipe through the wall, i then have a t on the outside of the house and a vertical pipe.
Do i seal everything inside and out? Or just inside? Seal the outside of the pipes or inside to? I don't seal the adapter to the stove do i?
Thanks im getting some smokey smell and i put the carbon monixide detector o nthe stove and got a little bit reading of a 15
woodsman23 said:
Yes seal everything!!.......
Woodsman, just curious....if it's outside the house, why does it need to be sealed? Doesn't seem to be necessary, IMO.
Well Mac is most likely does not need to be but why not just seal it up completley and have peace of mind...?
I suppose......
macman said:
I suppose......
Or not!!! I think it is users choice, as for me i do not have anything taped outsdie the house, but that's just me.
Chris04626 said:
where do i foind this tape my local true value doesnt have it near all the other sealent and cement
Lowes, HD, or your local plumbing/heating supply carries the foil tape. Should be in the same area as soldering supplies, etc.
