Propper way to use moisture meter
J-RO
Just wondering what is the proper way to use my moisture meter, do i use it on a fresh split peice of wood on the split side or use it on the side that has been split for a while? Why i ask is that ive been getting conflicting numbers, i cut my wood down so i can load n-s and when i put the meter on the freshly cut part of the wood im getting alot higher number than i am when i move it to the side that has been split at first. Is this normal?
Yes you should be measuring on the freshly split face. Not a fresh cut end. From my understanding the pins should go parallel with the grain.
pen
pen
I get exactly the same readings on a fresh split compared to a fresh cut, tried it on many pieces and it was always the same, as long as it is a fresh split or cut it makes no difference for mine.
oldspark said:
pen
The literature I've read always says to go parallel to the grain. I've actually never tried on the end with mine to see if it makes a difference. Have to give it a go sometime to compare.
pen
Spark your 3 year old season wood is dry all the way thru , ha ha
