quad cb1200 cleaning
corkman
721
SE,Mass
i recently bought a used cb1200 insert.today is the 1st day i got to do any work on it.i removed the baffles to expose the tubes and cleaned everything inside that i could get to.is there a way to expose the lower half of the tubes.removing the baffles only exposes the upper half.how do you clean the lower half of the tubes.the pull rod on the left works fine and slides nice and easy to clean the tubes but the one on the right will only come up about half way.anyone have a suggestion on how to free that up.
failed the dollar bill test so made an adjustment to door latch and all seems good now
i removed the combustion blower and the 2 cleanouts and cleaned everything out there.cleaned exhaust path right back to liner connection.convection blower will be next
disconnected tube from vac switch and blew it out.
any suggestions on what else i should do before prepping for install.Peace,Cork
