For some reason I have one cleaning rod that sticks out about 1/2 inch further than the other, don't know why I'm careful about using them when the stove is off.Is it a problem, and is there a way to fix? Thanks
I had the same problem on my castile, however after pulling the cleaning rods, the left one finally went back in all the way after a little extra push, no problems since..
Thanks guys, I'll be giving it a thorough cleaning this week, and will go over it with a fine tooth comb. Seems like build up seems to be the consensus. Thanks!
I agree it's probably buildup on the back plate or the far face of one rod. But if you can't get them even, take a look at the photo of my Castile in this post: https://www.hearth.com/talk/threads/castile-efficiency.120009/#post-1611111
On each side, the end of a screw acts as a stop for the rod. Maybe one of yours broke off?
Good point swineflue, or loosened up.I had a set screw drop out of the door handle yesterday, so how well they were tightened in the factory I don't know.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
