I have just installed a Quadra-Fire 7100 and am having trouble understanding the operation of the Automatic Combustion Control. There are two levers for combustion control, one is the "Automatic Combustion Control" and the other is the "Combustion Control Override". In the Owner's manual on page 10, whoever wrote it got lazy and just started referring to the "Combustion Air Control" lever. I got confused as to which lever they meant when they say things. I have three questions that might clear things up:
1) what position should the "Combustion Control Override" need to be in when using the "Automatic Combustion Control", or does it even matter?
2) Approximately how long does the automatic combustion control take to go from open to the desired set point? 2 minutes? a half hour?
3) Is there any way of knowing that the automatic combustion control is even working other than estimation by the fire rate?
To date (2 days of operation) I have been using the override as I can't seem to make the automatic control work. Thanks for any help
The timer will hold the damper open and slowly close the damper to where ever the ACC lever is set. At times you might possibly accidentally reset and restart the timer by moving the ACC lever to far to the right again ( based on if the lever was far enough to the left when you started moving it to the right).
