This pellet stove was one my father bought and is at our camp which is about 3 hrs away. He has since passed and I have now inherited what seems recently to be a nightmare. The problem is the stove burns for between 10-20 minutes and then dies down and stops. It seems as though it stops calling for fuel. The flames get smaller and smaller and eventually there's just a little pile of pellet coals in the burner. This is what I have done so far, as far as trouble shooting goes...
I have cleaned the entire stove, removed burn pit and cleaned thoroughly, inspected it and the ignition, cleaned and vacuumed the heat exchanges, cleaned and vacuumed all the pellets and dust from the hopper, cleaned all the fans, and checked the vacuum line. Inspected the thermocouple and its ceramic cover. I jump the thermostat on the back of the stove to see if it might be that, to no avail. I also have played with the feed setting and the placement of the ceramic thermocouple cover, adjusting each 1/4" at a time.
Somethings I noticed while monkeying around...
the wires for snap disc #2 (don't remember what color, thinking purple, but the ones that control the blower) have been unplugged from the snap disc and jumped
I see in the owners manual there is mention of a control box. My best guess is that this is suppose to be on the right hand side of the stove under the reset button and controls for the blower and heat output. However I don't have anything there. Again, there is a wire harness @ the bottom (below the reset button) and there is a jump wire there also.
This stove has burned for a few years with out any problems in it's current state/setup and nothing has been changed on it. I'm at a lose as to what I should do next. My guess is the control box is pretty important, but again it has been working fine without it.
Any advice would be greatly appreciated.
