Quadra fire classic Bay 1200 thermostat wire question.
Brian T
34
New Jersey
Hello,
I am installing a CB 1200 I just bought used. I have what may be a dumb question.
The manual says the thermostat wires attach to the 2 center screws on the terminal block, but doesn't say which side the red and white wires go on. Does anybody know?
Thanks
Sent from my SCH-I535 using Tapatalk
Hello,
Thanks
It does not matter. The is just a on/off switch that does not require 24V. All the thermostat is doing in this case is completing a circuit. As long as you are using a mechanical thermostat you should be fine. Anything other than you need a 24 v supply.
Reactions: Brian T
