Quadrafire 4100i
Macz311 Posted By Macz311, Nov 19, 2013 at 12:16 PM
Thread Status:
  1. Macz311
    Macz311
    New Member 2.
    NULL
    Nov 19, 2013
    4
    0
    Loc:
    Connecticut
    So I have had my quadrafire 4100 for about 3 months. Since the first breakin in fires, my glass has been getting excessively dirty. Tech has come out and tried modifying the baffle blanket, then we removed it, but it is still happening.
    It seems to draft well and at first, it stays clear, but slowly it begins to get covered in soot. It is very frustrating because I cannot watch the fire for long and I must clean the glass after each fire (not an easy task). Any suggestions on what could be wrong or what I can suggest to the tech? They are just as puzzled as I am.
    Thank you.
  2. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    Welcome to the forum.
    The first thing that comes to mind, and the most likely, is the quality of wood in terms of moisture content. Tell us about the wood. Species, moisture content, how long split and stacked, etc.
    Whatever the problem, I'm sure we can help with it.
  3. Macz311
    Macz311
    New Member 2.
    NULL
    Nov 19, 2013
    4
    0
    Loc:
    Connecticut
    Thanks so much for the reply, wood is oak. The trees fell during hurricane Irene 2 years ago. Last year it was split, stacked and covered. To eliminate the possibility of bad wood, I purchased kiln dried hard wood and still had the same problem.
  4. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,497
    6,073
    Loc:
    Northern IL
    What is the build of your stack? How tall? Bends? Air setting on stove? Stove temps? (I realize that you have an insert, but can you get a reading off of the front corner of the stove?)
  5. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    You did the right thing by trying the kiln dried wood. That helps. Poor draft can do it but you say it seems adequate. However, it may not really be. Could you be turning the air down a little too soon? Take us through a typical burning protocol and what stove temperature you're operating at.
    BTW, it may not be the direct cause of the immediate issue, but you need to be aware that oak needs more than a year to dry sufficiently to burn well. Some say as long as three years. It's a really slow drying species. Be sure to use the kiln dried stuff when you're doing the troubleshooting for this.
  6. Macz311
    Macz311
    New Member 2.
    NULL
    Nov 19, 2013
    4
    0
    Loc:
    Connecticut
    Quad has a start up air control allowing a lot of air in, then it closes down automatically. sometimes I crack the door to get a real hot fire. I leave the burn rate control open for a few hours or until I'm at about 450. I add hardwood periodically to keep a consistent burn and I have the ghost flames associated with the burning smoke. By the time the stove is up to temp. I already have build up on the glass and it progressively gets worse. I thought the air wash system was suppose to keep the glass clean, but it seems to be failing.
    The tech suggested possibly extending the chimney, but said it was not a short one to begin with (14 feet).
    Thanks for the tip about the wood, I have other hardwood mixed in that is even dryer and older, so I'm not thinking this is the problem, but I will keep burning the kiln dry for now.
  7. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,497
    6,073
    Loc:
    Northern IL
    Is this the primary air lever? If so, there should be no need to leave that wide open. After a well established fire, it should be adjusted way down on the low end of the scale (maybe 5-25% open, depending on your install). If you do this, what do the stove temps do?
  8. Macz311
    Macz311
    New Member 2.
    NULL
    Nov 19, 2013
    4
    0
    Loc:
    Connecticut
    Yes, and The primary air control is only open until the stove reaches peak performance, then I dial it down to maintain a hot fire without over firing the stove. Am I running it too hot for too long?
  9. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,497
    6,073
    Loc:
    Northern IL
    Being an insert - where are you measuring the stove temp? I have no preconceived notion at this point, just trying to gather as much info as possible to help us help you. Dirty glass is not typically an indicator of running too hot. It is just the opposite (normally).
  10. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    Well, you are, but that may or may not be interfering with the air wash. But what it will do is waste a lot of fuel with too much heat going up the flue. Typically, you should be able to start turning the air down in several steps when the fire is burning well, the flue temps are above creosote levels and the secondaries are burning. I can do that by the time the stove top is 250F. YMMV as always.
  11. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,497
    6,073
    Loc:
    Northern IL
    I wait till I hit greater than 500F stove top. Point being that some of this stuff is just operational pref. I don't mind sending a little heat up the stack during startup. I even make it a point to hit north of 800F on the stack temp (probe reading).
  12. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    True, and there are many differences in installations. My stack temps reach 800 in the first few minutes (maybe 5 or so) and will hit over1200 if I don't catch it in time. I also notice that the sooner I can safely turn the air down, the quicker the stove gets up to temp with the secondaries.
    I have to say I am surprised that you wait for 500, though. But whatever works, works.
  13. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,497
    6,073
    Loc:
    Northern IL
    At 500 stove top with wide open primary I have a stack temp of ~800. Right where I want it to hit. Then I tune it down for the long haul. Stack temp drops and stove top will climb a bit.
  14. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    14' might be a bit marginal. Some makers require 15, but many stoves get away okay with 13, like mine does. Hard to say in your case.
    It's actually the "few hours" part that I'm more curious about than the 450 degree part. How long does it usually take to get to 450?
Thread Status:
