Have Quadrafire Contour (10 yrs old) that goes out after 2 hours. Also takes 4 resets to start. Fire irregular - up and down. Any advice on fix? Terribly cold in Boston area - appreciate help!
In hopper feed rate slide opened up? Seems I have tried to get this thread up several times from moderation today!?
Welcome
I agree, sounds like your feed rate is too slow. If you can adjust it, open it up some. Another option is to buy another brand of pellets. I've seen a lot of different size pellets between brands.
Since I've not seen you post before I'll ask the normal questions.
When was the last time the stove and vent system was completely taken apart and cleaned.
Is the venting cap plugged up with ash, if you have one.
Are the holes in the burn pot open if you have them.
When was the last time the gaskets were changed or checked?
If the stove is running off a thermostat check the connections to make sure they are ok and change the batteries depending on your thermo type.
Have you changed the brand of pellets you have been using and if so are there long pellets in the bags?
Just trying to throw some ideas to you.
Hopefully someone with your make, with more knowledge then myself, will be along to help you get your stove sorted out.
Can you tell if it is getting enough fuel or not? Have you checked up the drop chute with a flashlight and mirror for any obstruction or bridging? Have you checked the firepot thermocouple to make sure it is good and is also touching the inside end of the cover? And can you tell if the auger is going backwards sometimes when running? Normally it will turn clockwise looking down from the motor end. If it is reversing, the capacitor is bad. You can purchase a capacitor jumper part # 230-2150. kap
If your stove is a contour, it should be older then 10 years, but not by much. The capacitor on older models is in the junction box. In newer models, roughly 2005 or a tad earlier, it is in line on the auger motor wire harness. You can pull the auger assy. and test it.Just jump vac switch wires together, making sure they can't ground out on anything. Leave auger assy wired to stove, when you pull it out, and turn thermostat up. Auger will start turning.And then also make sure the set screw is holding auger firmly to shaft and not slipping. Remember you only have 60 seconds as this is how long the initial feed lasts, You will have to hit reset button if you need more time. Make sure to unplug stove first, before jumping wires together to avoid any shocks or shorts.. kap
