Question About Old Jotul 118 Gaskets
neverrude
122
NJ
The manual from the 118 CB calls for
Size Length
Top Plate 3/8” 7ft
Flue Collar LD/SA 3ft
Door LD 360mm 8.7x850mm
Could someone please tell what does LD/SA & LD stand for.
Thanks.
I would guess that LD might mean linear dimension. Not sure about SA, maybe Standard Adapter?
I believe LD stands for low density (as opposed to high density).
That make more sense than linear dimension. Does SA stand for silicone adhesive?
SA is self adhesive
Thank you, one & all. :)
I’m just about ready to start reassemble on the 118b but I just want to make sure I get the right gaskets. For the top it says 3/8", I believe that is round or should that be flat 3/8"?
The door is 1/4", is that also round?
