Right now I am operating my stove with only a 36" triple wall pipe.
from the install it is about 3 inches into the house, 7.5 inches past joist and 1 inch past the plywood and shingles.
This gives me 11.5 inches taken off before it exits the roof.
Dura-vent Duraplus says if I go more than 4feet I need to have a brace for it.
Even if I add a two foot section of pipe that is only putting me a 4' 1" I should not need a brace correct?
The reason why I ask is because I have to jam pack my stove box and have the air wide open to get the flue temp to 425 degrees.
Will a longer chimney create a better draft to get up to higher temps where I can cut off some of the air supply and regulate so I can have an extended burn.
I know its a lot of question but feel free to chime in.
To be honest, I think I am only 1ft over the ridge which is 6ft away.
Another note, I have a 2-12 pitch roof.
